will 853 gaskets work on LS2???
Old 01-15-2008, 11:58 AM
TXsilverado's Avatar
Default will 853 gaskets work on LS2???
i pulled the 853 heads from my LS1 with the stock gasket. sold them to a guy with a LS2. he called me back saying they wouldnt work because he would need to shave alot off to make it work because he needs to use MLS gaskets.
he said something about the stock gasket imprinting the head and needing to shave like .07 off to make it work with the gasket? whats the deal with this? he ended up with 241 heads. i didnt think there was any difference between the 853 and 241 other than the sand cast vs die cast thing?
Old 01-15-2008, 12:28 PM
ugh...i meant 853 heads in the title. can someone change it for me?
Old 01-15-2008, 01:30 PM
kistlerjm9's Avatar
853 and 241 are the same, casting difference u mentioned is correct. what he is talking about is cleaning the gasket surface on the heads and with a good 3m buffing pad there will not be problems of leaking. he just needs to clean the surface not shave anything off unless they are warped.
Old 01-15-2008, 04:48 PM
he said the gasket indented the head. or some crap like that and he was guna have to take alot off to make it work. hmmmm
Old 01-15-2008, 05:06 PM
kistlerjm9's Avatar
a graphite gasket is a bitch to get off but its not gonna etch the heads hes smoking crack
Old 01-15-2008, 08:25 PM
transAm-98's Avatar
^ it may look like it's imprinted but it's all just left over graphite. He just needs to go to town with a scotch pad and a 3M scraper.
Old 01-16-2008, 05:16 PM
here is what he said...does it make more sense now? i always thought the 853and 241 heads were exact minus the casting process.
the 853 heads have a casting piece in them for the old graphite gaskets and wont work with the new MLS gaskets without leaking and they dont make a graphite gasket for the 6.0L
Old 01-16-2008, 07:38 PM
transAm-98's Avatar
I thought that i heard that you can't use the graphite GASKETS on the later blocks, but you should still be able to use the MLS gaskets with the heads. I may be wrong though
Old 01-17-2008, 02:25 PM
anyone got a for sure answer on this one? i already told him i would buy the heads back from him...im just trying to figure out if the reasoning was correct or not?
Old 01-17-2008, 02:57 PM
Sawzall and Welder Mod
Whistler's Avatar
The 853 heads have a notch on the bottom of the deck sealing surface that will cause a coolant leak when using MLS gaskets. Without welding the deck and resurfacing the heads, the 853 heads will NOT work with MLS. The graphite gaskets can be used on later engines, though there's not much reason to.
Old 01-17-2008, 03:00 PM
Whistler's Avatar
Here's a pic of the notch. It's probably .090 deep.
Quick Reply: will 853 gaskets work on LS2???
