other then Assembly Lube , is there any way to !!!
other then Assembly Lube , is there any way to Get oil throught engine ? before runin
other then using assembly lube , is there any way to run oil around in the engine , as it would normally run when the engine is running ?
Mine is a Weldon 9200-A, it is used to pump diff fluid or trans oil to coolers in a road race car. I use it with a -6 to power steering adapter which is 14mm like our oil galley plugs, just put a -6 o-ring over the threads on the power steering adapter and screw it into the side of the block up by the pump.
Kurt
Kurt
