Anything else Im missing for my engine swap?
So the 402 is in, with -10cc pistons, the 5.3s will be coming out of ths old LS1 and and my Torquer cam will be reused. so will the caddy lifters and my YT rockers or maybe Ill just use my Harland sharp rebuilt rockers, hardened pushrods 7.4" with .045" gaskets, 36# fuel injectors, TR55 spark plugs gapped at .040" , swapping over my old water pump or a new one, my powerbond underdrive pulley, my double roller timing chain, LS6 oil pump, my old oil pan, new gasket, old sensors, etc... oil coil packs, oil coils(have 100 miles on em, just like the rest of my valvetrain and heads... gonna reuse the pacesetter headers and LS6 manifold, PNP stocker TB, 85mm SLP MAF(brand new) but I got my car tuned speed density.. and SLP lid..
what else do I gotta know for this swap. Im gonna be using my LS7 clutch for the first couple hundred miles because Im gonna first break in my engine before my clutch... Im gonna use the hard break in process.... I dunno if Im gonna need to tune it before, and if so, how can I do that? if I need to break it in especially the first 20 miles?
Is there anything else I should know, in particular from doing this swap?
i have a powerbond 25% u/d
I wanna just reuse it all the time, thats why I went with it.
5.3 heads and tv3 cam
my oil pump is a ported LS6 oil pump...
Im thinking
new serpentine, alternator, waterpump, etc...since its a brand new engine and my heads, cam and valvetrain have literally 100 or so miles on them...
the oldest thing on my car is gonna be the oil pan and oil pickup tube(unless the new block came with one)
Oh and my LS6 manifold is also old, but my headers have about 8000 - 10000 miles on them.
well since the first 20 miles is most crucial to break in, I cannot tune it, since Id surpass those 20 miles while its getting tuned.
my tuner said its okay touse stock injectors to break it on...
Stock fuel pump, thatll be changed soon, but 36# injectors will be replaced...
I will install injectors when I tune it, for now Im gonna run my stock injectors til i break it in...
https://ls1tech.com/forums/new-products-showcase/885242-billet-alt-pulleys-ready-ship.html
https://ls1tech.com/forums/new-products-showcase/871747-ttp-s-new-4130-chromemoly-subframe-connectors.html
https://ls1tech.com/forums/new-products-showcase/859495-race-ramps-lowered-vehicles.html
https://ls1tech.com/forums/new-products-showcase/842481-spohn-pinto-manual-rack-kits.html
https://ls1tech.com/forums/new-products-showcase/839763-427-forged-short-block.html
https://ls1tech.com/forums/new-products-showcase/738632-new-carbon-fiber-valve-covers-sdpc.html
https://ls1tech.com/forums/new-products-showcase/708701-remote-clutch-bleeder-new-tech-sponsor.html
