Race Ramps For Lowered Vehicles!
Do you have a lowered car that makes it really difficult to drive up on ramps?
Tired of using pieces of wood to try and get your car up on the ramps only to have the ramps slide out of the way?
Here's your solution!!
67 Inch XT Race Ramps
Race Ramps 67 inch XT models are constructed specifically for use with even lower ground clearance cars! They are lightweight but strong and can hold up to 3000 lbs. Built in one solid piece they are durable and strudy and can work on any level surface.
Features:
* 100% Solid on all Planes. Solid Core
* 10.69 degree approach angle!
* Will not damage your hot asphalt, cement, or painted floors
* Will absolutely not slide on any surface
* Will accommodate tires 12” wide
* Hold up to 3000 pounds per set
* Gets your vehicle up even higher (10")
* Only thirty pounds per set
![](https://www.fasttoys.net/shop/images/raceramps67.jpg)
![](https://www.fasttoys.net/shop/images/raceramps672.jpg)
These are on sale right now for 268.99
We also have a 56" version (for cars not as low) for 186.99
Check out our full line of ramp products at:
http://fasttoys.net/shop/index.php?cPath=800
Features:
