best place to get a 402cid shortblock ?
We have seven LS2 402 cid short-blocks in stock as of today. We have them with our -2cc flat-top, -10cc dish, and -15cc dish setups. We have them built both with Eagle and Callies crankshafts, as well as standard ARP 8740 and ARP 2000 rod bolts. All of our engines use our exclusive Total Seal ring set with the Napier second ring. Feel free to give me a call or PM me, and I'll be glad to see which one will be best suited for your needs. FYI, all of our piston sets are built to accomodate the L92 valve configuration, so you'll have that option, whether now or later on down the road. We also have a free crate and cradle on some of our in-stock engines, so we can save you some money on that, too!
Jon
Texas Speed & Performance
Jon
We can have a 402 turned around for you to meet your needs in a matter of a couple weeks. We use premium Wiseco pistons with coated skirts, and 3MM oil rings to reduce friction.
All of our engines are built to your needs, to order, and IN HOUSE with no outsourcing whatsoever. When you buy a Weber Racing Engine, it is actually a Weber Racing engine, machined, balanced, and assembled by Weber Racing Equipment!
All engines are full CNC blueprinted and well as blueprinted for assembly. All rotating assemblies are individually balanced IN HOUSE. We use the actual weights of the parts going in YOUR engine, not a generic weight listed by the manufactures. This ensures a quiet and balanced assembly.
You can see the amount of detail that is put into each and every one of our engines in our engine follow along here:
https://ls1tech.com/forums/sponsor-vehicle-projects-shop-tours/882165-follow-along-engine-build-weber-racing-engines.html
