What is the longest stroke crankshaft I can fit in a Ls3?
I was going to use a 4.1 but I see callies makes a 4.1250 I'm wondering if that will fit. Thanks
Moderator
I would just keep it safe with a 4.00" stroke.
Are you going to use a power add is the question. If your not using a power add you can use the bigger stroke without issue. I'm running a sleeved LS2 with a 4.250 stroke. Its an advanced build but just to show you it can be done. You need the right builder to do it properly but power add should be out of the question over the 4" stroke.
Marty
Yep, better to spend your cash on the heads and intake for the small amount of cubes you will lose. Edcmat-l1 is doing me a RED sleeved LS2 as we speak
So 4.1 should go in that nicely.
