LS2 K1 crankshaft WARNING
Old 06-02-2008, 02:15 PM
bigturboz28's Avatar
Default LS2 K1 crankshaft WARNING
The pilot hole depth on the K1 crankshaft is shallow, I just had a short built with one in it and it can not mate up my T56 on my F-Body. I spoke with K1 and apparantly the design was modeled off an auto car, and they are working on fixing it on the new cranks. The recomended fix is grinding the input shaft of the tranny (upto ~0.150" depending on the plug they put in the crank - these vary too.). The rep said the plug could also be drilled if the intreference was not too deep.
Just thought you should know...
Old 06-02-2008, 10:07 PM
KCS
Moderator
KCS's Avatar
Thanks for the heads up. I think we are actually waitng on a few.
Old 06-09-2008, 08:46 PM
K1tom's Avatar
As stated above, the early cranks we produced were made to fit cars with an automatic transmission. While some could be mated to a manual transmission by removing approximately .020” from the end of the input shaft, we have made modifications to our design and all cranks currently being shipped will work with either type of transmission.
Tom Molnar
K1 Technologies
Old 06-10-2008, 08:46 AM
ScottyRocket's Avatar
I don't mean to bag on K1, just curious why wouldn't have this been a good idea to do from the start?
I know in my business the more applications a single product works with the better.
Old 06-10-2008, 10:09 AM
veee8's Avatar
I believe it was an oversight. Not intentional.
Old 06-14-2008, 11:47 AM
oreo11zeus's Avatar
Default K1
Never heard of a K1 crankshaft - Is this a good product? I am thinking of purchasing one for my Race Boat and Cigarette. I am running 800HP and 700 HP on the Cig. Looking for a 4.375 build on a 807 casting Bowtie 10.2 tall deck.
http://www.eriemonster.com
Old 06-14-2008, 03:50 PM
99ssleeper's Avatar
So....the K1 crank was modeled off an A4 car. What's the difference between a crank in an A4 car and the crank in an M6 car? I'm guessing nothing other than one comes with a pilot bearing. Why wouldn't the flange and the rear of the crank be modeled off a stock LS1 crank rather than the front of whatever transmission might be used with it? It would seem like the obvious approach so that you know either transmission will work. ?
Old 06-17-2008, 01:46 PM
Mikey 97Z M6's Avatar
K1 Industries have been around awhile now. They are now a division of Carrillo and could be compared to Compstar as far as quality goes.
Mike
Old 06-17-2008, 08:09 PM
Tom@SpeedInc's Avatar
K1 is part of Dover corporation currently
Old 06-18-2008, 07:46 AM
briannutter's Avatar
Yep, as an update. Dover (PMI) sold Carrillo a few weeks ago and kept K1...along with JE and Wiseco.
Old 06-18-2008, 01:03 PM
Crazy changes lol.... Apparently alot has happend since the SEMA show.
Mike
Quick Reply: LS2 K1 crankshaft WARNING
