Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
harmonic balancer bolt
Old 10-31-2014, 04:20 AM
06vzssthunder's Avatar
Default harmonic balancer bolt
Just wondering how everyone goes about doing up the harmonic balancer bolt without the crank spinning?
Old 10-31-2014, 06:26 AM
smamar's Avatar
Old 10-31-2014, 06:37 AM
Originally Posted by smamar
I guess the gearbox has to come off to use it? Where abouts do you get it from? cheers.
Old 11-01-2014, 01:32 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
You bolt it where the starter mounts. The bellhousing can stay on.
Car Shop Inc.
Andrew
Old 11-01-2014, 10:42 PM
Sweet saves me the troubles of taken the gearbox. thanks for the replys.
Old 11-05-2014, 02:21 PM
Exidous's Avatar
In a stick I put the car in 4th and put the e-brake on. 4th being a direct connection between input and output shafts. If the driveline can take 400+ftlb of tq against my steady 230ft lb I think it will be just fine. Works every time. Just need a BIG *** torque wrench.
Old 11-17-2014, 07:02 AM
got myself one of them flywheel locks just need to wait for it to be sent to Aus.
Old 12-13-2014, 03:03 PM
ls3velle's Avatar
Default bolt
Where did you get lock the fly wheel lock
Old 12-13-2014, 04:08 PM
Scroll up...I posted a link.
Andrew
Old 12-24-2014, 01:24 PM
MickGIS's Avatar
Hey I just read about another option to keep the crank from rotating when removing the old crank bolt and installing the new crank bolt.
This works on a Gen5 Camaro with a 6 speed manual transmission:
  1. Put the car in 4th gear
  2. Set the park brake
  3. Chock the tires to keep them from rolling
Sounds like a reasonable procedure.
Old 12-24-2014, 07:48 PM
MickGIS's Avatar
I asked the Guy on LS1Tech and he said:
"Yes I have them. $35 Shipped in the USA $50 to canada..."
Thanks for the tip.
Payed Tim on LS1Tech via PayPal and less then two hours later the tool was shipped, amazing.
Old 12-27-2014, 04:48 PM
MickGIS's Avatar
Default Vendor For A Crank Torque-to-Yield Bolt
I found the crank torque-to-yield bolt a couple of places:
Speed Engineering - GM LS3 Harmonic Balancer Bolt - $12.09 + shipping
GM Parts Direct - Bolt 11570046 - $7.59 + shipping
GM LS3 Harmonic Balancer Bolt M16 X 2 X 125.75mm - $12.09 + shipping
Anyone have a vendor for this crank torque-to-yield bolt they trust and recommend?
Old 01-01-2015, 05:40 PM
sierravmax's Avatar
You could just get a ARP bolt and call it done. Not sure how much you are looking to spend though. They usually run about $34.00
Quick Reply: harmonic balancer bolt
