What alternator should i be running procharged ls1
I know this has probably been asked a 1000 times, but i need a alternator with more amps down low. My dash lights and hids surge like crazy at night. I did the big 3 which didn't really help at all. I currently have a stock alternator on the car with big 3 and new optima battery. Whats my best choice for one? I know i can run a truck alternator cause it will hit my procharger, and can i take my alternator off with out removing the blower? Thanks guys.
I'd step up to a Powermaster 48206 (F-Body) - about 110 amps at idle which is pretty much the peak of the stock alt.
Change the alternator quick because Redtop Batteries do NOT like weak alternators. When they drain, even a healthy alternator alone won't be enough to bring it back to life and it requires a special charging process in order to revive it.
