Generation V Internal Engine 2013-20xx LT1
Gen 5 LT1 swap
Old 02-17-2017, 03:54 AM
Igaragellc's Avatar
Default Gen v lt1 swap
I have swapped the gen v 6.2 from the corvette in my 70 chevelle looks great turns over all day but still no start...no power to the injectors and my hp tuners or scanner will not connect to ecm?..
Old 02-26-2017, 08:40 PM
Igaragellc's Avatar
Default Gen v lt1 c7 engine swap in chevelle
I have swapped the c7 lt1 in my 1970 chevelle. She runs like a champ. I hope to repainted it soon n be riding. Check out my YouTube...gen v swap chevelle.
Old 02-26-2017, 09:55 PM
CapriceLS's Avatar
Congrats! I def will be following your YouTube channel.
Old 05-20-2017, 04:12 PM
Marquez Jerry's Avatar
Any one has info on what i need to drop a 2017 lt1 motor into my 84 Chevy c10?
Old 05-21-2017, 10:21 PM
Default 84 Chevy c10 2017 lt1 swap
Any info on how I should go about swapping a gen 5 LT1 into 84 Chevy c10 pick-up.
Old 06-07-2017, 11:06 AM
Transamthunder's Avatar
There are several companies making swap mounts for older small blocks, and I did see a company that also specializes in older Chevy tricks. I dont wanna drop any names if they arent sponsers, but I did find them through Googling then recently.
Old 06-07-2017, 11:53 PM
CapriceLS's Avatar
Not sure if this is the correct place to post but I'm selling a set of the dirty dingo slider gen V swap mounts for $75 shipped. Comes with bolts. Was just used for mock up.
Old 06-08-2017, 12:30 AM
Default 2016 Camaro SS
Is the engine in the 2016 Camaro an LS motor or LT1, and how can I determine which one i have.
Old 06-08-2017, 07:52 AM
Received 3,022 Likes on 2,353 Posts
The 2016 Camaro uses the LT1
Old 08-15-2017, 09:30 AM
TigerTruck's Avatar
I'm getting ready to start a Gen V LT1 swap into an 88 IROC. Slowly doing all the research and just started buying parts. One thing seems to be a problem. Headers. I can't find a vendor who makes them for this swap. I found flanges and was wonder if I should just get LS headers and change the flanges. Would this work?
Old 08-19-2017, 12:48 PM
Jimbo1367's Avatar
Check out Holley for the swap pan and TB spacer. The pan is like the 2nd, Holley pan. (Fbody)
Old 10-13-2017, 06:48 AM
  #32
Jenson's Avatar
It appears to me you could possibly swap a Gen V with a LT4 blower and actually fit under the stock 4th gen cowl...I'm very intrigued by this theory
Old 10-27-2017, 05:29 AM
  #33
Rob94hawk's Avatar
Originally Posted by redtan
The biggest problem will be with the computer, as one will need to be able to control both the engine AND the interior stuff. Not sure if anyone has done the work for that yet.
^^This right here. Especially with my 94 Fbody. This would be the biggest hurdle.
That and if it would actually fit in this cramped engine bay with headers.
With my Firehawk hood I have plenty of clearance for the supercharger.
Probably would have to use a 4" exhaust.
Old 10-28-2017, 01:53 PM
  #34
Rob94hawk's Avatar
BTW am I looking at the schematics right? The fuel pump is on the back of the engine and not in the tank?
Old 10-28-2017, 02:50 PM
  #35
Kermitt47's Avatar
The engine fuel pump is the high pressure pump for the DI injectors. You still need a lower pressure pump to supply the DI pump.
Old 10-29-2017, 10:00 AM
  #36
Rob94hawk's Avatar
Wondering if the Walbro pump I already have is sufficient then.
Old 10-30-2017, 01:25 AM
  #37
Kermitt47's Avatar
Check out this thread on the fuel pump requirements.
https://ls1tech.com/forums/generatio...questions.html
Old 11-02-2017, 09:25 AM
  #38
Rob94hawk's Avatar
Are shops bore and stroking this block yet? Aftermarket blocks? Max cubic inches? etc?
Old 04-27-2018, 12:27 AM
  #39
Rob94hawk's Avatar
Nothing yet still? Damn. Very surprised.
Old 04-27-2018, 10:53 AM
  #40
Heat Seeker WS6's Avatar
A Gen V LT1 in a 4th gen would be awesome- especially in a 93-97! Wish I had the $$ for this
Quick Reply: Gen 5 LT1 swap
