Katech Gen 5 LT1/LT4 AFM delete valley cover now available
Our Gen 5 LT1/LT4 AFM delete valley cover is now available. This allows you to easily delete AFM on cars with larger camshafts.
-Requires non-AFM lifters
-Requires transfer of some parts from old valley cover
--Oil pressure sensor
--PCV valve/fitting
--PCV baffle
--Valley cover gasket
Order online:
http://store.katechengines.com/gen-5...over-p440.aspx
--PCV valve/fitting
--PCV baffle
Order online:
LS1Tech Premium Sponsor
This Katech valley cover is an awesome idea. We just finished up a cam swap in a C7 last week and figuring out how to block off the ports under the valley cover were kind of pain.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
LT1 LT4 L83 L86 Gen V engine Lifters failure.
I'm thinking pre 2007 non Displacement On Demand , Variable Valve Timing, Active Fuel Management is the way to go if good, simple, reliable, and economical is the goal.
I hope I don't get to start chanting "DEATH TO THE GEN V"
