Gen V Head bolts
Chinese Head Studs
HI, the GM LS engine is designed to assembled ONCE ONLY.
The MAIN REASON for the TTY bolts.
This engine family was NEVER designed to be rebuilt !
The NEED for several changes are necessary.
One such change is to fit head studs, I sell a "china" stud kit @ $85.00.
The reason I am firm on this is that the block threads will "strip" on the third torque/rebuild.
The yield of my kit is the SAME as the GM bolt, NOT GREATER.
Another common problem is the rocker arm bolts, they too have a need for a "steel insert" in the head.
ALL racing AL block engines use studs in EVERY location.
Lance
Lance
