My 98 SS slp and 01 Turbo F150
Old 02-11-2009, 08:34 PM
atexasguy18's Avatar
Default My 98 SS slp and 01 Turbo F150
Just wanted to show off my new Camaro
And the Truck
and the money shot
Old 02-11-2009, 08:35 PM
madmike9396's Avatar
Nice......
Old 02-11-2009, 08:37 PM
egott_91's Avatar
Nice. Now get her cleaned up!!!
gbal4's Avatar
wow very nice!!
Old 02-11-2009, 08:39 PM
Texnmissouri69's Avatar
OK!!! Where the hell is the motor?!?!?!?!
Old 02-11-2009, 09:20 PM
Thanks, you can almost see the engine in this one
Old 02-11-2009, 10:59 PM
So what #'s are you hitting with that massive turbo??
Old 02-12-2009, 07:31 AM
I was wondering if someone was going to ask about that
It has 303rwhp and 360rwtq 4.2L v6, 4r70w trans.
stock cam and heads
that's what I'm here to learn about
I'm trying to figure out what cam I should go with and what direction to go with the heads for the truck.
I've seen guys on the ford v6 sites use LS1/LS6 springs on heads like mine, but guys on the v6 sites seem to use really tame cams even with thier poweradders. I want something a little meaner.
am I in the right place? will the information about LS turbo cams relate to my engine?
Old 02-12-2009, 08:19 PM
Grand National 5-0's Avatar
you are not going to want to put a really aggressive cam in a turbo car because big cams have overlap (both valves open at the same time) and you will lose your boost back into the cylinder.
Old 02-12-2009, 09:04 PM
thats good to know, that why Im here
my kit was actually designed after the Grand National turbo setup, just on the drivers side
It just made since because ford also stole the engine design from buick too
I hang out turbobuick.com every now and then, I need to spend more time on there
how much boost are you running GN?
Old 02-12-2009, 09:14 PM
Texas 02 Z28's Avatar
Nice cars!
Old 02-12-2009, 09:16 PM
im running 28# with alky, and i see what you mean by using the same design with the exception of the turbo being turned so the inlet is facing forward instead of to the side. did you build the kit yourself or.....? Also what size hairdryer is that?
Old 02-12-2009, 09:44 PM
Thanks, Another guy on v6f150.com designed it for "production" but everything fell through and I was the lucky winner that ended up with the kit about 3 years ago.
Garrett 4088= 88mm
GN I see your a marine, are you still serving, what do you do?
Old 02-12-2009, 10:53 PM
yeah im still in for about another month. ive been in for 5 years and its time to move on. Im Military Police Officer.
Thats a pretty big turbo for that V6 to be spinnin....what rpm do you spool at? I assume your in texas, where at?
Old 02-13-2009, 06:20 AM
I'm in Denton, Tx its about 40min north of dallas
I dont have a tach, but i would guess aroung 2500-3000
It has a little bit of a turbo lag problem. Could a cam help out with that?
I know that new torque converter with a high stall would help
Old 02-14-2009, 03:48 AM
BlazerManZQ8's Avatar
And the Truck
Very nice, even the ford! have u raced them together yet??
Old 02-14-2009, 01:52 PM
nah, I haven't pitted them against each other yet.
what do the LS1's run in the 1/8th like an 8.5?
Well my truck ran a 10 second 1/8 with a 2.2 60ft.
some of that is bad reaction but turbo lag is a b!tch
If I wanna run with the camaro, I think I could use a 3500 stall converter and maybe a 25 shot to get me out of the hole? shrug
oh and I need the quarter mile, so I can chase the camoro down. That would probably be a better race
