new guy in tn with ws6
hey guys i been checkin the site out for a while so i finaly joined up. my name is josh and heres a couple pics of my 2000 ws6, 445rwhp 453tq all motor. thanks guys, hope u enjoy
im in clarksville
-ls1 aluminum block
-ls1crank, 3.622 stroke
-scat ls1 h beam connecting rods, .927 wrist pins, set of 8, with upgraded apr 2000 bolts
-diamond racing ls1 forged flat top with 2cc valve releifs, 3.905 bore, 3.622 stroke, 6.122 rod length, .927 x 2.50 wrist pins included
-mahle racing 3.905 pro select piston rings 1.5/1.5/3.0mm file fit
-camshaft bearing set for ls2 and 2nd gen ls1 block
-clevite connecting rod bearings, ls1, per bearing,for stock crank applications
-clevite main bearing set for ls1 applications, stock
-gm bolt for ls1/ls2 side main cap and ls2 rear cover
-gm ls1 oil restrictor
-gm ls1 oil galley core plug
-gm ls1 large cooland plug
-gm engine block small coolant plug, lsx based engines
-precision race comp stg 2.5 5.3 heads
-v3 cam 231/234 .643/.598 111.
-ls7 lifter kit
-in motion ls1 double roller timing set with torrington bearing
-ls1/ls2 cam retainer plate
-arp lsx cam retainer bolt kit
-arp ls1/ls2/ls6 cam bolt kit
-ls1 lifter tray bolt
-ls1 lifter trays
-ls1 cylinder head gasket, pair
-ls1/ls6 cylinder head bolt kit, per cyl head
-ls1/ls2 timing cover gasket
-ls1/ls2 rear main seal housing gasket
-valley cover gasket
-ls1/ls6 oil pump and o ring
-ls1/ls6 balancer pully bolt
-ls1 exhasut manifold gasket
-ls1 oil pan gasket
-ls1 water pump gasket per side
-lsx rear main seal
-ls1 front cam seal
-stg 4 clutch and flywheel
-fast ls6 intake
-pace setter headers
-slp lid
-full slp loudmouth exhaust
-39lbs injectors
and a few other things are done to the car as well as far as subframe connectors etc etc
-ls1 aluminum block
-ls7 lifter kit
-ls1 lifter trays
-ls1 oil pan gasket
-lsx rear main seal
-ls1 front cam seal
-fast ls6 intake
-slp lid
-39lbs injectors
