4L60E hard 1st gear shift
Old 07-06-2009, 04:16 PM
edward361's Avatar
Default 4L60E hard 1st gear shift
I'm getting full line pressure from park to 1st and 1st to 2nd, the trans. code is P0748 which is the pressure control solenoid. I replaced the PCS and also replaced the TCC enable solenoid and wiring harness in the trans. This did not solve the problem. This engine & tranny is out of a 99 camero ss and is in my street rod, I used a painless performance wiring harness. the trans. always worked this way since the install. everything else seems to be working good. I even ran power through the harness to make sure there were no breaks in the harness. I also checked all the resistance in the rest of the solenoids and thay all checked out good. Does anybody have any suggestions. Thanks!
