Loop for lowered car and 3.5" DS
Title pretty much explains it all. I have a 02 Z28 lowered on strano springs and a 3.5" aluminum driveshaft and i'm looking for a loop that will work. i have a spohn loop but it rubs. i could probably try and shim the loop to make it larger, but i'd rather find one that will fit right off the bat because i fear the shimming might make it structurally weaker. anyone have any experience? thanks
I have a Jegs and I'm lowered about 2 1/4", only have a 3" driveshaft, but there is clearance for a 3.5. It could easily be shimmed down a bit if you need to for driveshaft clearance. Only $35, but you do have to take out the front seats and pull up the carpet to install.
LS1Tech Premium Sponsor
I have a tunnel form-fitting loop that should work with the 3.5" shaft. nothing hangs low and clears long style torque arms and almost any exhaust. bolt-in 1pc construction, black or red powdercoated. 90.00 shipped.
http://i271.photobucket.com/albums/j...8/IMG_1206.jpg
