Safe nex shot with a 5 PSi boost( Stock)
I was wondering if it is safe to spray a 150 shot with a vortechS/C 5PSI boost, on a stock ls1 without breaking. If not what would be a safe nex shot. thanks
the general rule of thumb for stock ls1 is 8-10 psi and roughly 550rwhp. Id say pulley it down and get 8psi out of it. Maybe even look at a meth injection kit to keep down iat's.
n2o doesnt not cool anything down, it will actaully heat things up and create high cylinder pressure.
yep I agree. don't use a shot on the setup you have until your motor is built. there is no point to spend the extra dollars for it when you can just swap out the pulley for 7 or 8 psi. there has been many people run 8 psi on a stock motor & safe tune and do ok. you'll hit over 500rwhp @ 8.
