*** Timing advice needed asap ***
Just curious if there i any "risk" throwing a couple degrees in my car at the track. Rough breakdown of my set-up:
370ci 9.1:1cr
T4ST80 at ~11psi
dual nozzle alky control kit running pure meth
91 octane with a gallon or two of 110 mixed in a full tank
17* built into the tune
I have efi live and can add a couple degrees if I want. Ambient temps should be in the 75--85* range or cooler.
Whatcha think? I figured I'd be okay throwing a couple more in it if I need to shave a few hundreths
370ci 9.1:1cr
T4ST80 at ~11psi
1 Post
370ci 9.1:1cr
T4ST80 at ~11psi
370ci 9.1:1cr
T4ST80 at ~11psi
As a side point, I ran a fat 11.1 AFR on my STS, but bumped the timing to 20* safely. It was only 5PSI, but the principle is the same.
Good luck on the 9's. At least it's not raining where you are.....like here
12 Second Truck Club
How are you able to add timing but not boost if the tune is locked????
I run 12 psi with a fat afr. low 11 high 10 . and 20 deg. timing and strait meth. Going from 18 - 20 gave me 25 hp or so.
Im also stock motor
Im also stock motor
