*** Timing advice needed asap ***
Old Oct 17, 2008 | 04:51 PM
ninetres's Avatar
Default *** Timing advice needed asap ***
Just curious if there i any "risk" throwing a couple degrees in my car at the track. Rough breakdown of my set-up:
370ci 9.1:1cr
T4ST80 at ~11psi
dual nozzle alky control kit running pure meth
91 octane with a gallon or two of 110 mixed in a full tank
17* built into the tune
I have efi live and can add a couple degrees if I want. Ambient temps should be in the 75--85* range or cooler.
Whatcha think? I figured I'd be okay throwing a couple more in it if I need to shave a few hundreths
Old Oct 17, 2008 | 04:56 PM
sevanseriesta's Avatar
looking for 9's huh.... Are you talking 2 degrees or more? Can you not just up the boost to try that instead?
Old Oct 17, 2008 | 05:01 PM
Schantin's Avatar
370ci 9.1:1cr
T4ST80 at ~11psi
Give it an initial baseline run at the track on 17* and check the knock tables. If they look good (ie no knock) with a stable AFR (11.xx), then you can try a couple degrees. If it begins recording knock, get off the gas and bring it back to the previous 17*.
As a side point, I ran a fat 11.1 AFR on my STS, but bumped the timing to 20* safely. It was only 5PSI, but the principle is the same.
Good luck on the 9's. At least it's not raining where you are.....like here
Old Oct 17, 2008 | 05:04 PM
ninetres's Avatar
I am LOW 11.XX AFR too. I talked to my tuner and he said just go 1* at a time and I should be fine with 20. Can't up the boost because the tune is locked.
Black X's Avatar
I think you should be OK with the good fuel and meth.
Best of luck... got get them 9's
Old Oct 17, 2008 | 05:26 PM
what do you mean the tune is locked, are you saying that the tuner locked the PCM.
Old Oct 17, 2008 | 05:33 PM
ninetres's Avatar
correct
Old Oct 17, 2008 | 05:56 PM
WJ MARK's Avatar
12 Second Truck Club
How are you able to add timing but not boost if the tune is locked????
I run 12 psi with a fat afr. low 11 high 10 . and 20 deg. timing and strait meth. Going from 18 - 20 gave me 25 hp or so.
Im also stock motor
Old Oct 17, 2008 | 06:01 PM
Timing Tuner, or something to that sort
Old Oct 17, 2008 | 06:04 PM
Zombie's Avatar
with 16psi and 100 octane i'm 17 degrees at the tq peak and 23 at 7000.
Old Oct 17, 2008 | 06:14 PM
I thought you were going to the track today zombie
Old Oct 17, 2008 | 06:27 PM
ninetres's Avatar
EFI live can add timing while it is running, but can not permanatly alter a locked tune.
Old Oct 17, 2008 | 06:29 PM
thats interesting, did not know that!
Old Oct 17, 2008 | 06:35 PM
cablebandit's Avatar
hptuners does it as well...its in the bidirectional controls
Old Oct 17, 2008 | 06:40 PM
Zombie's Avatar
I am, it doesn't open until 9pm though.
Old Oct 17, 2008 | 06:48 PM
Ohhh, you are 2 hours behind me.... My bad
