Initial D1SC plan
Old 10-20-2008, 11:50 AM
11Second Club
Gauge's Avatar
Default Initial D1SC plan
Hey all,
I'm trying to justify buying a D1SC kit before tax return time comes. Specifically, I want to try to get the blower on the car without buying a new set of heads. Here's my situation:
I had to rebuild my engine at one point a couple years ago. I decided to get Mahle -9cc dished pistons and forged Compstar rods. To keep my CR up while I was N/A, I milled the heads .040" and put .040" gaskets on there. The end result was something like 10.28:1 CR assuming a 61cc CC after milling. I never had the heads CC tested, so that's just a guess based on how much I milled.
The cam in the car is a TR 230/236 on a 112 LSA. It's a pretty hefty cam for a blower, as I understand it, but I've seen similar setups do quite well. I'm planning on keeping this cam at first.
The question I have is how much boost I could run on this setup if I were to drop the CR down closer to 9.9:1 with stock head gaskets and the cam, what kind of boost could I run? Ultimately, I'd like to see 625+RWHP with heads, lower CR, etc, but if I can do 575+RWHP now without buying heads, I'm going to pull the trigger!
Old 10-20-2008, 11:54 AM
No Juice's Avatar
10-12 lbs should be no problem with a good tune at 10:1 compression. That will get you to your goal easily
Old 10-20-2008, 12:04 PM
11Second Club
Gauge's Avatar
Actually, I just read that the stock MLS headgaskets are .060". I was using .054" in my math. If that's the case, then I could get it down to 9.8:1.
So, does everyone agree that 12psi would be safe on pump gas with a FMIC on that setup, and that 575+RWHP would be an easily attainable goal with stock heads?
Thanks, for the response, No Juice. (I'm really hoping Bob will chime in, too!)
Old 10-20-2008, 12:07 PM
No Juice's Avatar
I thought they were about .053" as well?
Old 10-20-2008, 07:28 PM
EPP
EPP's Avatar
Thumbs up
Your compression ratio will be just fine at 12 psi of boost. I see 575 rwhp being a problem though, as you'll have a hard time only making that much power! lol
Check this GTO out that made 532 rwhp with 8 psi of boost and headers and exhaust. http://www.exoticperformanceplus.com...Car.php?car=46 Bob
Old 10-21-2008, 12:11 PM
11Second Club
Gauge's Avatar
Thanks for the reply, Bob. I'll be on the phone again with you eventually to iron out the details. I just have to grow a pair and drop the cash, lol.
Old 10-24-2008, 04:47 AM
EPP
EPP's Avatar
Thumbs up
Sounds good, give me a call when you're ready! Bob
