Need new BMR poly bushing, where do I get ?
Like title says the bushing on my BMR adj panhard is really badly worn and needs replaced. Can this be found at any local automotive places?? Also whats involved to press one in place ?
Here you can see the wear:
Found the problem!
Guess I figured out why the rear would step out on hard corners one way LOL
Found the problem!
Now that is a worn bushing! I had to replace my bushings in my old BMR non adjustable upper A-arms a while back. If you give them a call they will ship you the right part. It's not expensive and it was pretty easy to swap out.
