LT1 cam/lift question
I need some advice for my 93 M6 LT1.
I'm just starting to do some simple mods for my formula, its my daily driver so I want decent mileage yet (not terribly important), but I want a little more power under the hood. I've got all my cosmetics done so now it's time for some performance mods.
What I want is a cam that I can put in without having to burn a new chip for my computer.
Also I was wondering what the max valve lift is on stock LT1 heads with stock valve springs.
SD requires a bunch of baby sitting! if you do a cam you will need a chip done no question about that.......as far as valve springs they are barley sufficient for the stock cam much less a performance orientated cam!
i would suggest at this point you do more research as to what really works and the steps involved to achieve a goal without damaging the motor and spending money on mistakes.......
New valvesprings
New retainers
New valve locks
New 1.6 roller rockers
New hardened pushrods
New guide plates
255 lph fuel pump
you have no sig so, i will also say you need hedders!
possibly at this point you are ready for a camshaft swap,timing chain and a chip or dyno tune to get you started.....
when you see the big picture purchasing a set of LE heads and custom cam begin to look less expensive for the gain
New valvesprings
New retainers
New valve locks
New guide plates
255 lph fuel pump
you really dont need a 255pump i got a stock pump with a cam and 36lb injec....works perfect and made some decent number on the dyno. id go custom cam threw "ai" they made me a very happy customer
New valvesprings
New retainers
New valve locks
New guide plates
255 lph fuel pump
New retainers
New valve locks
New guide plates
255 lph fuel pump
If you're trying to do this on a budget though, you don't need the hardened pushrods and guide plates UNLESS you go with NSA Roller Rockers. You should be fine on the stock Fuel Pump too.
93 6 speed LT1 Formula, 3:23 gears, 93,000 miles, 1 of 92 93' green formulas with a 6 speed and t-tops.
