where to start
Old 10-22-2008, 02:42 PM
acidrain088's Avatar
Default where to start
building a boost motor and im not sure exactly to start. its going to go in a street rod so im currently looking for a totaled lsi camaro or firebird 99+. i was hoping for about 800 whp with a tc76 or 78 at largest not looking for too much lag. im planing on building the bottom end adding some ls6 heads and a decent boost cam (high lsa). i was wondering if i was on the right track first of all and also if you would have any siggestions. another question i have is what do you guys do about high hp/tq tranies and rear ends. im assuming the stock rear end goes pretty fast and so does the trany. will the stock 10 bolt hold up after a build or is it the best idea to go with a ford 9 inch and a built powerglide or muncie. i know this isnt the best place to ask about that but i figure while im at it i might as well ask cuz u guys got the highest #s
thanks in advance for the input
Old 10-22-2008, 02:51 PM
LS1TECH Sponsor
DrTurbo's Avatar
800rwhp is running a TC78 slap out. Leave yourself some room....go with a PT88 if you have to have a T4, if not then move up to a T6.
Old 10-22-2008, 02:59 PM
bigti99a's Avatar
i wouldnt want to drive something with those power numbers on a stock trans and rear. get forged bottom end and i agree that you dont want to be maxing out your turbo to get to your goal.
Old 10-22-2008, 03:59 PM
would a lq4/lq9 be the way to go.
Old 10-22-2008, 04:01 PM
slomarao's Avatar
yep, iron all day.
Old 10-23-2008, 05:02 AM
EPP
EPP's Avatar
Look at the build on this V that we did this year using an LS2 block.
http://www.exoticperformanceplus.com...Car.php?car=29 Bob
Old 10-23-2008, 06:44 AM
98transguy's Avatar
i use a 4l80e tranny and a 9 inch for my power levels 800+rwhp on high boost.I didnt want to lose my overdrive so hence the more expensive built 4l80 over a built th400
Old 10-26-2008, 01:08 AM
what exactly is aluminum block territority and will i need a completley new rotating assembley for that. i cant realy see a crank snapping in half.
