Anybody dynoed in cold weather? How does it effect it?
I’m interested in hearing from people who dynoed in cold weather (dyno room temp ~40-50F or lower)
What did you notice?
Was your SAE corrected power about the same? ? (assuming you dynoed before in different weather)
Was you’re A/F ratio effected by much? or at all?
Thanks. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ February 11, 2003, 11:12 AM: Message edited by: EuG ]</small>
Moderator
Re: Anybody dynoed in cold weather? How does it effect it?
I recently re-dynoed when I was changing TB's and it was 47 degrees in the garage with the dyno and about 38 degrees outside. I was having KR limit my maximum timing so I was down about 12 RWHP (SAE) but the un-corrected numbers were 4 RWHP higher than before due to the colder weather. There was actually a pop-up window warning note on the dyno software that stated caution when making comparisions with this data due to "extreme" temperature variation.
Thanks.
So you’re saying you saw some KR that you usually don’t see? Is that right?
Did you’re A/F change at all?
Thanks again! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> So you’re saying you saw some KR that you usually don’t see? Is that right?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, normally I have zero KR. My only conclusion was that I am either sucking too much oil (I have bought an LS6 PCV set-up but haven't installed it yet) because when I changed the TB's I could see that the intake was oil soaked inside and when I dynoed last summer I just put the heads on so their was no oil in the heads. I can't remember which gas station I stopped prior to this dyno run so it's also possible that I also had some oxygenated gas in the car too.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Did you’re A/F change at all?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It was running just a hair leaner but what was strange is that I was about 20+ RWHP down and I decided to reflash the PCM with the exact same program that it was already running and I immediately picked up ~13 RWHP....go figure!
Well, so after you re-flashed PCM you were basically only down ~7rwHP from normal? Is that right?
Perhaps computer learned something <img src="http://www.agrnet.com:8888/Pictures/Images/Smilies/Dunno.gif" alt=" - " />
Did you have any KR at that point (after reflash)?
If you were only within 7rwHP and possibly had some KR that you don’t normally have then I think we could assume that corrected numbers are pretty accurate regardless of the weather.
What do you think?
What do you think?
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Well, so after you re-flashed PCM you were basically only down ~7rwHP from normal?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, it was closer to nominal but still down a bit because the timing still saw about 2.5° KR
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Perhaps computer learned something. Did you have any KR at that point (after reflash)?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I got a little less KR than before the reflash (was about 3.5° before and 2.5° after) but it also ran a bit leaner....about 13:1 A/F instead of 12:8 before the reflash which made no sense to me. I suspect that the leaner A/F got me more power back than the less KR but who knows at this point.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I think we could assume that corrected numbers are pretty accurate regardless of the weather</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">At this point I would say you're probably right although I personally believe that for us folks living north that Std Corrected numbers (rather than SAE) are a better number to use since the weather conditions better reflect reality (I believe it is ~68° temp plus a higher level of humidity).
