2002 camaro brakes
2002 camaro brakes
need help on 2002 camaro what kind of brakes can i run ,so that i can use a 15 inch weld rim on the front .. can i run 93 disk brakes or ? this is a x-cop car do they have bigger brakes that a z-28 .....thanks
The brakes that came from the factory in the B4C (Special Service Coupe) were the same brakes as in the other Camaros of the same year. If the 15" Welds will work on regular Camaros and nobody put bigger aftermarket rotors on, you should be good.
