Ls2 Lifter Trays
or got his route:
Valve Lifters & Components
12499225LS Series Camshaft Lifter Kit (not shown)
• Set of 16 lifters for LS series engines
• Same lifter used in LS2 and LS7
17803305
Lifter Guide Kit
• Includes lifter guides and 4-bolts
• Makes for quick and easy cam swaps without having to
remove the intake manifold, valley plate or heads
• Works in Gen III and IV applications (except with AFM)
17803305
Lifter Guide Kit
LS1Tech Premium Sponsor
The Gen4 lifter trays will work perfectly on the Gen3, but not the other way around. The change was a small notch at the bottom that matches the Gen4 block....without the notch (gen3), the trays will not work on an LS2.
12551162 = LS1 Tray
12595365 = LS2 Tray
12551162 = LS1 Tray
12595365 = LS2 Tray
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
i have some for sale brand new in box still. . . .https://ls1tech.com/forums/lsx-parts-sale/1009281-243s-mti-x1-bunch-performance-parts-new-used.html
The kit I listed above should only be used in the LS1, LS6, LQ4 and LQ9 and a couple of other Gen III based engines. The kit contains the style that does not have the cutouts to clear the boss in the lifter valley. Those bosses are are there for engines that have or have the option of AFM, Gen IV engines. Sorry for the confusion.
