Who has an MSD Opti?
I am starting to think I might not have gotten the timing adjustment set right when i installed mine.
Can anyone tell me the way it should be stock and how you have it adjusted etc?
Thanks
Thanks
The only way you can verify it will be to measure. Make a TDC mark on the damper, fab up a pointer and check it with a dial back light. Well I guess you could use a damper with the degree marks and then use a standard light, but point is you will have to measure it.
If you still have the stock press fit only damper I would make the TDC mark temporary and assume it has moved and recheck it every time before verifying with a timing light.
