Speaking of 1.7 roller rockers...
I was reading through this thread on CZ28.com:
http://www.camaroz28.com/forums/show...ht=ls1+rockers
...and it got me curious.
If drilling out the stud holes on stock rockers is the only thing that needs to be done to LS1 rockers to make them fit LT1 heads, do you think it's possible to run LS1 shaft rockers on our heads as well?
(Since studs aren't even involved?)
A set of these would be a noiiiiiiice upgrade:
http://www.byunspeed.com/product_inf...oducts_id=5880
Anybody know if something like this is doable?
Check this post:
http://74.125.95.104/search?q=cache:...lnk&cd=4&gl=us
If I'm understanding how these shaft rockers were engineered, they mount up like a standard stud rocker normally would, but they replaced the studs with bolts.
Seems like all you'd need to do to run these on a set of LT1 heads is just find the correct size bolts?
Originally Posted by Mike @ New Era
Yella Terra's shaft-mount rockers are an easy and economical way of boosting power, torque and reliability in late model engines. When Yella Terra bolt on rockers are used, the conversion can be performed in the vehicle with no head removal or machining required. Yella Terra's shaft style rocker arms are suitable for hydraulic roller camshafts and feature oversize shafts and bearings for massive strength, stability and long life. No more needle bearings in your engine! Simply bolt on to original 8mm rocker mountings with no valve cover clearance problems! Eliminates studs, guide plates and special pushrods. These are the new lightweight design which makes them the lightest rocker on the market for higher reving engines .
