i started my cam install today!
Like it says today i started my cam install, so far everything is going kinda smoothly. i am installing the MS4 cam on tuesday because thats when it should be here, i am installing it with the motor in the car and the heads will not be taken off, i hope... i got as far as pulling out the factory cam! A few bumps in the road and they were pulling the radiator out, i needed a friend for that, crank pulley off, it helps to have the right tools, and i made my own JPR i used 5/16" SS rod and took my angle grinder and shaved off about 1/32" on one side to make it flat, and made the end pointed. they went in smoothly with some work and the lifters are held up now. so i hope the rest goes as well as this. i have not been taking pictures. i have been using LS1howto directions and they are great!
Just though i should share this, i feel kinda proud because this is the first major install.
LS1Tech Premium Sponsor
Sounds good man! Don't hesitate to call us if you get stuck on anything or need any advice!
It'll be a VERY rewarding feeling when she fires back up for the first time and you hear that camshaft...and know that you saved a big chunk of $$ doing it yourself!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
