2048.9 hp/1507.1 lbsTq 400ci LSX
Old 10-31-2008, 10:16 PM
Black_Phantom's Avatar
Default 2048.9 hp/1507.1 lbsTq 400ci LSX
I just came across this amazing built on Hot Rod Nov 08,you guys gotta check it out.
2048.9hp/1507.1lbs Tq @7140 RPM
specification:
400ci LSX Tall deck
callies crank 3.75 inc
GRP 6.125 inc
Diamond pistons 57cc, CH 1.403
Comp 254/257 0.775/0.776 114
prototype cylinder heads from GM 44cc
Twin Accel 2,100-cfm throttle bodies
custom tunnel ram-type intake manifold
pair of 88mm Precision turbochargers With Air/Water IC
front-mounted distributor with an Accel distributor and Mallory coil
Accel/DFI management system
Moroso 5 stage Dry-sump sys
Old 10-31-2008, 11:28 PM
Z06PSI's Avatar
Holy ****....Nice!!! How long will it last there though?
Old 11-01-2008, 12:02 AM
CalSpeedPerformance's Avatar
I personally think this build was done kind of odd...there was no need for alot of the parts they used and they spent twice as much as I would have to make the same power...
Old 11-01-2008, 12:11 AM
69TA's Avatar
that's like one them Nelson's engines out of Cali.
he makes crazy power like that.
but what's the point, anything over 600 on the street is basically useless.
Old 11-01-2008, 01:03 AM
1dirtyZ's Avatar
Whats wrong with a burnout at 200mph
Old 11-01-2008, 01:42 AM
cookba's Avatar
what good is power if you cant put it to the ground. with all that power i want to see track times?!?!
Old 11-01-2008, 02:17 AM
Over 600 on the street is useless?? lol... We must race different types of cars on the street....600 rwhp in my area runs "decent" ...
Old 11-01-2008, 05:06 AM
speedracer5532's Avatar
agree...they must not of ever driven a high hp car on the street with the right tires and good suspension. At 940 rwhp, I can hook my car from 50 mph and up on the street.
Old 11-01-2008, 06:04 AM
Z06PSI's Avatar
Who said this was a "Street" engine?
Old 11-01-2008, 07:24 AM
Mr.427's Avatar
Impressive build and love the intake. Really doesn't make any power until about 7000rpm on engine dyno. Put it under a load and i expect you will see that power band move a little more to the left.
Old 11-01-2008, 10:03 AM
GrahamHill's Avatar
Old 11-01-2008, 10:12 AM
mike13's Avatar
My wife says nothing we do when it comes to cars makes since. Builds like this are cool they show that it can be done.
Old 11-02-2008, 10:12 AM
No that was built by thomson engines
http://www.thomsonengines.com/lsturbo.cfm
Old 11-02-2008, 11:23 AM
NA$TY-TA's Avatar
Been around for a while and nothing new..... a few people on here make that much HP.
Its on an engine dyno so your talking 1700hp or so..... look at Major, Kempt, Phil, Wormboy, Both Ohio Boys....
How much HP do u thing it taked to run 200mph or close to in the 1/4
Race car yes.... street car no.
Old 11-02-2008, 03:28 PM
GrahamHill's Avatar
Are those the road race heads?
Old 11-02-2008, 04:10 PM
LS6427's Avatar
If you're car is not set-up properly and you have no clue how to drive a car with power, then 600 is too much for you. 600-RWHP is pathetic these days for the street or strip.
A friend of mine hooks just fine with his iron 422 + 300 shot and runs 50-180mph races.
Old 11-02-2008, 04:39 PM
xBROKEx's Avatar
something with that much power youd think would be for top speed runs on the salt flats or wherever they do those
Old 11-02-2008, 05:19 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I agree with SoCalSpd on the parts overkill thing. The best thing about this is that it shows us that GM is making the tall deck LSx blocks and I believe those heads are the ones talked about in the GEN IV internal section.
Quick Reply: 2048.9 hp/1507.1 lbsTq 400ci LSX
