What WOT bracket to use with Fast90/NW 90MM TB?
Old 11-02-2008, 02:32 PM
walterd's Avatar
Default What WOT bracket to use with Fast90/NW 90MM TB?
Does anyone have a LS1 with NW 90MM Throttle body, Fast 90, and N20?
What WOT bracket did you use looks like my old setup isn't going to work with the NW throttle body?
Thanks!
Walt
Old 11-02-2008, 04:04 PM
02SOMWS6's Avatar
I'm having the same issue. I have the 90/90 setup and a e/water pump. I had to make up my own bracket cause no one seems to make one that fits with the e/water pump. I do have a micro switch that would work if you don't have a e/water pump
Old 11-02-2008, 04:22 PM
walterd's Avatar
I am interested in the bracket since I don't have e-waterpump, do you have a picture or what would you want to ship it to Austin Tx, 78753?
Thanks!
Walt
