slp oil pump, which spring??
Old 11-03-2008, 01:20 AM
Restricted User
Lawnboy's Avatar
Default slp oil pump, which spring??
I am installing the SLP/melling oil pump on my forged LS6 , it comes with a extra spring, what spring should use , the higher press ure one???
I dont want to end up with 80psi at idel.
thank you for your help
Old 11-03-2008, 01:29 AM
BIG BAD BLACKSS's Avatar
Considering the built bottom end and the procharger you should go with the heavier spring in my opinion. I did with my forged 370 and D1SC. You should see about 5 more PSI at idle over the regular spring, its not some crazy difference, just a few more PSI.
Old 11-03-2008, 01:37 AM
Restricted User
Lawnboy's Avatar
Thanks Big Bad SS
what spring is already in the pump when shiped??
what oil pressure are U seeing ? you have the SLP pump?
Old 11-03-2008, 01:40 AM
16floz470ml's Avatar
Hey buddy. I have the pump and used the red spring. It is the hd spring. The pump will come with the weaker blue spring in it. You will need a 8mm allen socket to get out the stop. With my setup I have 40psi at hot idle and 60 at wot.
Old 11-03-2008, 02:06 AM
I have the SLP oil pump but my motor is still going together right now actually, I am going off all the research I have done for the last few years in setting up my combo.
Old 11-03-2008, 02:16 AM
Restricted User
Lawnboy's Avatar
OK sounds good
Quick Reply: slp oil pump, which spring??
