L92 Block oil and water plugs
Restricted User
I just bought a L92 block and I need to get all of the oil and water plugs for it. Is their a kit that comes with everything for a new block? I bellieve I need the dumb bells for the oil restricters for the rear of teh block, the two press in caps for the front, the screw in oil plug and the water plug. Am I missing anything and what are the part numbers for these??? I searched but came up with nothing.
gm makes a kit for the ls1 but nothing for the LS3/L92,, they are different
just go to the dealer and print out some pics and tell them what you need, make sure you get the dumb bell oil plug and the oil gallery plug for the front of the block, i just went through this with my LS3 build
Restricted User
So I need 2 rear dumbell plugs, two front oil galley plugs, 1 screw in oil plug and one screw in water plug correct??
Do a search for gen III block completion kit. It will include all the part numbers for the pieces you need. http://www.crateenginedepot.com/stor...P1738C113.aspx
not quite,, that is for ls1/ls2
LS3/L92 are different, sure some of the parts are the same but not all of them
