what size injectors ?
With wet you can moreso get away with it since it injects fuel and nitrous into the intake tract where dry you definetly need them because it injects only nitrous and relies on you having large enough injectors/pump. I would upgrade the fuel pump on either and upgrade the injectors on either if spraying alot but a reasonable amount should be ok with the stockers assuming good tune and everything else. That is atleast what the N20 guys at HSW told me when I was going to go the nitrous route.
The boys at Nitrous Outlet told me different..lol I did some major research on spraying before I decided to go with the LE2 package. I only investigated the wet plate set up. Pretty much all the guys over there said anything over a 100 shot I would need to replace the injectors. Who knows....
