Pushrod length ?????
OK, I've been going over and over everything I've done to my motor looking for little bits of HP here and there. I've now discovered that my pushrods might be too long. What issues will come from having pushrods that are too long? How does it affect the power? Any advice would be great. Thanks
Get a push rod length checker and find out what you need...
Last time I did it on dry lifters it was a very sensitive operation.. I set it to 7.000" and expand the tool in single turns until it stops spinning.. but it's DELICATE! You can't spin it like threading a bolt by hand, it's like you have to use the tips of your fingers.. . My buddy and I both did it twice and we came up with the same measurement..
Then add .050 - .075 on to your measurement for preload... (IIRC) After my H/C swap, I ended up with a final number of 7.350... So the 7.400" hardened pieces would work fine. ( .050" of preload won't kill a lifter... IMO)
LS1Tech Premium Sponsor
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
