Confused about window motor problem
Old 11-12-2008, 05:39 PM
TireSm0ke's Avatar
Default Confused about window motor problem
The windows will sometimes not go all the way up, not work for about 30 seconds, and then go up a little bit, then do the same thing. Happens going up or down, and on both windows, using both switches. Do I need to replace the motor, or is the regulator or relay going bad?
Old 11-12-2008, 05:51 PM
xephona's Avatar
https://ls1tech.com/forums/general-m...dow-motor.html
Old 11-12-2008, 06:50 PM
MongooseAtHeart's Avatar
window motors man, mine went out last winter kinda trick to change but lots of good info on the site for changing them out yourself.
