P0336 - Crank Shaft Sensor
Old 11-15-2008, 12:13 PM
GameOn911's Avatar
Default P0336 - Crank Shaft Sensor
I'm drawing the code P0336 - Crankshaft Position Sensor A CKT Range/Perf
I have replaced the sensor already and the code still shows up. When I take the sensor out the plate in the hole has play in it (is this normal?). Any suggestions on how to fix this?
Any suggestions on how to fix this? I am experience power loss, seems more prevelant under heavy load.
Thanks in advance!
Old 11-23-2008, 09:34 PM
GameOn911's Avatar
Bump, anyone have any thoughts or suggestions????
Old 11-24-2008, 12:52 AM
robsquikz28's Avatar
try putting a washer between the sensor and the timing cover it MIGHT go away or not but it does for some
Quick Reply: P0336 - Crank Shaft Sensor
