Need M6 swap parts!!!!!!!!
11 Second Truck Club
i pulled my M6 from an '01 Z for a Coan TH350 swap, i have every part you need to do the M6.... upgraded T56, clutch master, braided line w/ drill mod, centerforce dual clutch, flywheel, pro 5.0 shifter, cross member, body boot, all brackets/bolts/hardware, even include torque arm (will include pedals/linkage and console, but i would like trade for a set of auto pedals/linkage and auto console) ........ tranny grinds going in 4th, so it will need syncros..... $750 for all +s/h
Well I only need the parts listed. So can you PM me a price on the clutch master, braided line w/drill mod, cross member, boot, brackets bolts hardware, pedals and linkage.
Do you have the slave cylinder and pressure plate?
I don't need the torque arm, I have a BMR one. But I do need the torque arm mount. do you have the bushing? will it fit a BMR one?
I'd be happy to trade some of my A4 parts to you. Once I have all my parts in (trans and clutch should be here tomrrow) and the rest of the stuff I can start my swap. Once I pull it all out, I can send those pieces out.
i thought you needed the whole swap..... i would like to keep everything as 1 package, since the tranny isnt perfect, all the other stuff may be the selling point for it, you can pm me an offer for the stuff you need and i'll consider, i will do a trade on M6 pedals for auto pedals and black M6 console if you have a black auto console, but i need an auto shifter too
your new tranny should have the slave cylinder in it, if it doesnt, what you should do is to buy the adustable clutch master cyl kit from thunder racing, it has the master, braided line, slave and it is already bled, ready to be put in and best of all it can adjust the pedal feel....... the pressure plate should come with your clutch kit, i believe your thinking of the flywheel and yes i have it make an offer
if the bmr torque arm mounts in the same bracket as the stock TA then it should fit
