Serious wheel hop in need of help
Old 11-17-2008, 11:10 AM
nitr0racing21's Avatar
Default Serious wheel hop in need of help
When I am driving and decide to floor it I get wheel hop out the *** and its not safe at all what does everyone recommend to help me with it?
Old 11-17-2008, 11:16 AM
99FBODY's Avatar
lower control arms with relocation brackets would help out greatly.
Old 11-17-2008, 12:50 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Do you have any suspension mods done to the car? As 99 stated, lower control arms and relocation brackets will usually eliminate any wheel hop issues. We offer several different styles of lower control arms from a poly/poly boxed or tubular non adjustable to a full out QA1 rod ended on car adjustable version. The non adjustable versions are available in either 1.625" x.110 dom steel or 1.625" x .083 moly steel. The adjustable version is 1.25" x .095 chrome moly steel. The relocation bracket brackets are available in a bolt in or weld in version. Both are made from 3/16" laser cut cold rolled steel allowing for up to 3" of "instant center" adjustment.
http://www.bmrfabrication.com/F4.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-17-2008, 02:18 PM
PewterMNZ's Avatar
DO you need relo brackets if you are stock height and having wheel hop ?
Old 11-17-2008, 02:57 PM
BMR Tech2's Avatar
Just the addition of lower control arms might cure the problem. If not the relocation brackets will.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-17-2008, 03:00 PM
2FAST4U's Avatar
I am no expert on this but at stock height I had bad wheel hop. Whole car would shake. I had LCA and Torque arm but what ended up fixing it was relocation brackets and changed torque arm angle. Allso different tires helped me. with less air.
Old 11-17-2008, 05:04 PM
LS1TECH Sponsor
Sam Strano's Avatar
A lot of things can be involved in wheelhop. LCA brackets and so on aren't always the answer... In fact shocks can effect hop as much as anything else (compression damping controls unsprung weight, and the axle and everything bolted to it is unsprung weight).
So while LCA's, brackets, TA's, and all can help lessen or cure wheelhop....they can't stop hop coming from shot dampers. And more than once we've had cars that had all the suspension parts listed above installed, and they still hoped and only shocks stopped it.
There are ways to help narrow the field to see if shocks will help the hop, and I'd be more than happy to discuss options and how parts effect different aspects of driveability.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 11-17-2008, 05:10 PM
Well now shocks are a good possibility it does have 102,000 miles on it I think I will start and change the shocks and look into what other parts wear out
Old 11-17-2008, 05:40 PM
LS1TECH Sponsor
Sam Strano's Avatar
More than a possibility w/102k miles on OEM's........
Just want to make sure you know that all shocks aren't the same anymore than all cams are, or tires are. Depending on use my recommendations are Bilstein or Koni 99% of the time. Sometimes Tokico or AGX's, but it's pretty rare.
__________________
Old 11-17-2008, 06:01 PM
michaelg589's Avatar
I myself had UMI LCAs and Bilstein shocks and still had wheel hop. I have since changed to KONIs but havnt really noticed if the wheel hop is totally gone yet. I suppose if I were to also get a Torque Arm, wheel hop would go away completely.
My front shocks were blown out before 80,000 miles, with the stock springs
Old 11-17-2008, 06:07 PM
Ok so now I want the best handling info I want shocks springs etc etc, I Track my car very often I plan on asking for suspension for xmas and doing performance myself. Xmas is a great perk when living at home
Old 11-18-2008, 09:46 AM
Anyone out there with some advice for the new guy? I don't know car suspension very very
Old 11-18-2008, 03:23 PM
Start with Bilsteins and some poly-rod Lower control arms (along with some reloc. brackets if you feel like spending a little extra)
too bad you didnt post a little sooner. I JUST sold my bilsteins.
Old 11-18-2008, 04:21 PM
z28bryan's Avatar
It's hard to give the right advice here... Are you going to really do hardcore, wheel lifting drag racing? If not then I'd get Konis. Koni's will give you pretty decent drag racing results. If your shocks are assisting in the wheel hop, then konis will prevent at least the rebound from occurring too quickly.
You're main problem here is wheel hop though.... from what I've read, relo brackets will help prevent wheel hop. Shocks help prevent wheel hop. There's probably other things as well.
