what size tb and injectors
Old 11-18-2008, 05:33 PM
th3brandon's Avatar
Default what size tb and injectors
iam building a 383 with a gm847 cam ported stock heads...and all other supporting mods just as the title says what do u guys recommand for a setup like this...i will be sparying up to a 150 shot if that matters as well...any help will be great
Old 11-18-2008, 06:02 PM
kinglt-1's Avatar
Ford svo 42lb (green top's) will work well with your setup.
Old 11-18-2008, 06:13 PM
th3brandon's Avatar
thats what i was thinking 42lb and 58mm tb...where can i buy those injectors at?????
Old 11-18-2008, 08:40 PM
kinglt-1's Avatar
look around on ebay or the fs section here. They normally can be had from anywhere between 175.00-250.00 used. New they are 400.00
