346 v 364/370 for tc78
I already have the ebay kit and I am pretty sure I am going with the tc78 turbo. My question is what size motor. Looking to run 15 psi max. Keep in mind this kit has a 3" dp. I think the 346 is more suited for the 3" hp, but with the larger motors I think the max hp would be higher, the spool quicker and more off boost power. Thinking of running 8.8-9.1 cr.
Thanks
Thanks
Larger displacement will have more off-boost torque, will spool the turbo faster, and will make more power for the same amount of boost, period. Even @ 15psi, you could set it up to run 9.25-9.5:1 and still be good to go. You're right on the 3" DP, it would work great on a 346, but you can get a good compact sized turbo that makes over 600whp and still uses a 3" downpipe!
I like lower compression and more boost. Its more forgiving. My 370 wasnt bad when it was N/A. I drove it around for 1500 miles or so before the turbo setup went on. It had no problem spooling the turbo at 2200rpms eigther.
This subject is debated a lot. I've tried several different displacements with the PT76GTS and wound up at 388 cid, which I like the best.
It's like this... if you plan on running lots of boost and making the most hp possible, then go with the smallest one. If this were the case, you might even consider a 4.8 liter build. But, you'd have to run 25+ psi boost to get the numbers. Conversely, if you want max hp at a lower boost level, like 15 psi, then go with the biggest one.
My goal was to maximize hp on pump gas (15-17 psi), so I went 388 even though I had already run 383 and 360 cid.
