Long Torque arm, but not mounted on tailshaft
I havent checked recently on TAs, but Ive heard that there are Torque arms that are the stock length or (long), but they have a relocation to mount on the crossmember?? or something, but not on the tail shaft.... Now , hopefully it does mount to the crossmember and not the chassis...
My whole reasoning for such a request is, I do drag race this car, but I also road race it and The short TA really sucks on decel when I road race, Ive wheel hopped many times because of the short TA... This is my MAIN reason for asking if such a TA exists and if so, who makes it??...
MY TA (which is a UMI TA) also has a D/S safety loop and I have 3 pt UMI SFC, which also add extra weight to the car, but are recommended to run with the chassis mounted TAs....
So if a torque arm does exist that is the longer length and is npot mounted to the chassis, id like to purchase it. ALso Ill save a good 30lbs removing my 3pt SFCs (Im getting a 5 or 6 pt rollbar welded anyways)
So hopefully someone could help me with this issue...
I ordered an adjustable torque arm made for regular length and then just got a crossmember built for the relocation. That's all there is to it.
Several sponsors make them. I think BMR and Yank both have some models of varied prices. Feel free to chime in with a comprehensive list but those are the only ones I could think of off the top of my head.
UMI and BMR both have transmission crossmembers with a built in TA relocation mount.
A factory TA, or factory sized/style aftermarket TA is what their designed for.
http://www.umiperformance.com/produc...ategory_id=131
Scroll down to bottom of page
http://www.bmrfabrication.com/F-bodyChassis.htm
Hello,
Yes we have both items you are looking for and I posted two links below... please take a look and let me know if you have any questions.
www.umiperformance.com/2205
www.umiperformance.com/2207
Thank you!
Ryan
Thank you!
Ryan
LS1Tech Premium Sponsor
http://www.bmrfabrication.com/F4.htm
Relocating the torque arm off of the transmission is not going to stop wheel hop. You will have instant center adjustment and the the benefits of a full length torque arm. The main reason to relocate your torque arm is to save the transmission tailshaft from breaking.
