Largest Hydraulic XE-R grind
Old 09-23-2003, 08:17 AM
Formerly 4mulaJoe
LS1x2's Avatar
Default Largest Hydraulic XE-R grind
So who is running the largest XE-R hydraulic roller cam or one with similar ramps? What does your valvetrain setup look like and what are your results?
Old 09-23-2003, 09:13 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Default Re: Largest Hydraulic XE-R grind
Just ordered my 239/251//581/595//116 XE-R cam from Comp Cams
Old 09-23-2003, 09:17 AM
gator's 99TA's Avatar
OMG on a 116 lsa? that thing is gonna peak WAY high!
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Here is the XE-R chart. 248/.615 is the biggest listed on that chart.
Thats a pretty big lobe...
Old 09-23-2003, 09:49 AM
7 Second Club
Phil99vette's Avatar
Thats the first time seeing that chart...interesting how it recommends Comp R's and 977s.
Phillip
Old 09-23-2003, 07:21 PM
Vents's Avatar
Good info once again, but from my understanding, thats not a complete chart there j-rod. i've got a 238 ex (non XER) lobe on my cam, and it's not shown. hrmm.. mark @ comp was telling me for some odd reason that the biggest lobe they had was a 242 at the time. perhaps this is a later chart, or i was just mis-informed.
Old 09-23-2003, 11:53 PM
D(irecto)r Pepper
Raughammer's Avatar
Call 1-800 cam help to talk to CC and get the newest info.
Man that chart is old, i had it on my web page for years.
Good luck Joe
Old 09-24-2003, 09:37 AM
J-Rod's Avatar
I have a buddy @ Comp sending me the master Lobe Catalog. I will try to scan the appropriate sections and post them up.
Old 09-24-2003, 09:52 AM
ROB'S SS's Avatar
i have a 236/238 601/605 on a 111 with 2* advance. stock lifters and combinations new ex-616 springs(stock bottom end). still working out tranny and converter issues, but the valvetrain is holding up fine and is not too loud either. we will be checking spring pressures after we switch from the 5.7 heads to the 5.3 heads. after we put the 400 tranny in, we can work on some more solid numbers
Old 09-24-2003, 07:20 PM
pimpmaro's Avatar
I thought the larger the LSA, the wider and lower the powerband was? I was under the impression that a smaller LSA narrowed and raised the peak?
Old 09-25-2003, 02:02 AM
Bowtieman4life's Avatar
opposite
Old 09-25-2003, 03:05 AM
kumar75150's Avatar
I have a 244/250 634 625 lift on 112lsa cam
Old 09-25-2003, 09:02 AM
Formerly 4mulaJoe
LS1x2's Avatar
What is your valvetrain setup like?
Old 09-25-2003, 09:37 AM
93Polo's Avatar
Was this in a 395 stroker?
