strongest u joints?
Old 11-27-2008, 08:44 AM
impaled's Avatar
Default strongest u joints?
i think i am going to replace my u-joints on my formula. i have a little bit of vibration and am thinking one may be bad.
so far i am leaning towards Precision Super U joint. here is an excerpt from the description.
Precision Super U joint: $20
"Super strength universal joint. Abrasion resistant nitrate seals, microshield coating to prevent corrosion. Flush type lube fitting in end of bearing."
Lakewood also has a performance model: for $37
" high strength chrome-nickel-moly alloy cross and caps for improved fatigue resistance. The needle bearings are made from special high-carbon steel and induction heat-treated to maximize wear resistance."
which would you go for?
or is there a better brand?
i realize that i dont need the strongest as the stock 10 bolt is the the weak spot in the driveline, but i still want the strongest and longest lasting u joint.
Old 11-27-2008, 11:35 AM
35th SS's Avatar
just make sure its a solid ujoint without the grease fitting.
Old 11-27-2008, 02:25 PM
impaled's Avatar
alright. thanks. Precision it is then.
Old 11-27-2008, 03:57 PM
LM97Z's Avatar
Your solid joints will be the strongest.
Old 11-27-2008, 10:55 PM
35th SS's Avatar
now that youve replaced that you have to look for your weak link somewhere else.
Old 11-28-2008, 12:05 PM
impaled's Avatar
that would be the 10 bolt. i will at least try to make that last for a while... lol.
Old 11-28-2008, 12:20 PM
LM97Z's Avatar
just don't throw any $$$ into it, total waiste in the long run, my 2 cents.
Old 11-29-2008, 04:48 AM
35th SS's Avatar
I agree invest on a 9in. instead.
Old 11-29-2008, 08:19 AM
impaled's Avatar
i definitely know that. i am keeping a little bit of backup $$$ for a 9" when the 10 bolt dies.
Quick Reply: strongest u joints?
