strongest u joints?
i think i am going to replace my u-joints on my formula. i have a little bit of vibration and am thinking one may be bad.
so far i am leaning towards Precision Super U joint. here is an excerpt from the description.
Precision Super U joint: $20
"Super strength universal joint. Abrasion resistant nitrate seals, microshield coating to prevent corrosion. Flush type lube fitting in end of bearing."
Lakewood also has a performance model: for $37
" high strength chrome-nickel-moly alloy cross and caps for improved fatigue resistance. The needle bearings are made from special high-carbon steel and induction heat-treated to maximize wear resistance."
which would you go for?
or is there a better brand?
i realize that i dont need the strongest as the stock 10 bolt is the the weak spot in the driveline, but i still want the strongest and longest lasting u joint.
