Rod Bearing?
Rod Bearing?
Im have to change the rod bearings and i'm down to it, but I have a question about how to get this rod bearing out. It has the two bolts on the bottom but it all looks like it is one piece and not like all the other ones i've ever done. Has anyone else ran into this? just need some advice. Thanx in advance.
Re: Rod Bearing?
..the cracked rod is forged from a single piece of metal and is machined to size and then cracked in half...this keeps the rod in an almost perfect circle... ...most modern engines have cracked rods now; I think...
Re: Rod Bearing?
oh yeh, one other point....obviously, the cracked caps must be re-installed on the same rods as they were made from...in the same direction....therefore, mark these carefully before removing them...
Re: Rod Bearing?
Engine specs below:
Engine Type V8
Displacement 5.7L-5665 cc 346 CID
Bore 99.0 mm 3.898 in
Stroke 92.0 mm 3.622 in
Compression Ratio 10.1:1
Firing Order 1-8-7-2-6-5-4-3
Spark Plug Type 41-931
Spark Plug Gap 1.524 mm 0.06 in
Lubrication System 5.678 Liters 6.0 Quarts
Oil Capacity (without Oil Filter Change) 6.0 Quarts 5.7 Liters
Oil Capacity (with Oil Filter Change) 6.5 Quarts 6.151 Liters
Oil Pressure (Minimum -- Hot) 41.4 kPa at 1,000 engine RPM 6.0 psig at 1,000 engine RPM
Oil Pressure (Minimum- Hot) engine RPM 124.11 kPa at 2,000 engine RPM 165.48 kPa at 4,000 engine RPM
engine RPM 18.0 psig at 2,000 engine RPM 24.0 psig at 4,000 engine RPM
Oil Type Mobil(E) 5W-30 Synthetic or Equivalent
Camshaft
Camshaft End Play 0.025-0.305 mm 0.001-0.012 in
Camshaft Journal Diameter 54.99-55.04 mm 2.164-2.166 in
Camshaft Journal Diameter Out-of-Round 0.025 mm 0.001 in
Camshaft Lobe Lift (Intake) 7.04 mm 0.277 in
Camshaft Lobe Lift (Exhaust) 7.13 mm 0.281 in
Camshaft Runout (Measured at the Intermediate Journals) 0.05 mm 0.002 in
Connecting Rod
Connecting Rod Bearing Bore Diameter 56.505-56.525 mm 2.224-2.225 in
Connecting Rod Bearing Bore Out-of-Round (Production) 0.004 mm 0.00015 in
Connecting Rod Bearing Bore Out-of-Round (Service Limit) 0.008 mm 0.0003 in
Connecting Rod Bearing Clearance (Production) 0.015-0.063 mm 0.0006-0.00248 in
Connecting Rod Bearing Clearance (Service Limit) 0.015-0.076 mm 0.0006-0.003 in
Connecting Rod Side Clearance 0.11-0.51 mm 0.00433-0.02 in
Crankshaft
Crankshaft Bearing Clearance (Production) 0.018-0.054 mm 0.0007-0.00212 in
Crankshaft Connecting Rod Journal Diameter (Production) 53.318-53.338 mm 2.0991-2.0999 in
Crankshaft Connecting Rod Journal Diameter (Service Limit) 53.308 mm (Minimum) 2.0987 in (Minimum)
Crankshaft Connecting Rod Journal Taper (Production) 0.005 mm (Maximum for 1/2 of Journal Length) 0.0002 in (Maximum for 1/2 of Journal Length)
Crankshaft Connecting Rod Journal Taper (Service Limit) 0.01 mm (Maximum) 0.0004 in (Maximum)
Crankshaft Connecting Rod Journal Out-of-Round (Production) 0.005 mm 0.0002 in
Crankshaft Connecting Rod Journal Out-of-Round (Service Limit) 0.01 mm 0.0004 in
Crankshaft End Play 0.04-0.2 mm 0.0015-0.0078 in
Crankshaft Main Journal Diameter (Production) 64.993-65.007 mm 2.558-2.559 in
Crankshaft Main Journal Diameter (Service Limit) 64.993 mm (Minimum) 2.558 in (Minimum)
Crankshaft Main Journal Out-of-Round (Production) 0.003 mm 0.000118 in
Crankshaft Main Journal Out-of-Round (Service Limit) 0.008 mm 0.0003 in
Crankshaft Main Journal Taper (Production) 0.01 mm 0.0004 in
Crankshaft Main Journal Taper (Service Limit) 0.02 mm 0.00078 in
Crankshaft Reluctor Ring Runout (Measured 1.0 mm (0.04 in) Below Tooth Diameter) 0.25 mm 0.01 in
Crankshaft Runout (at Rear Flange) 0.05 mm 0.002 in
Crankshaft Thrust Wall Runout 0.025 mm 0.001 in
Crankshaft Thrust Wall Width (Production) 26.14-26.22 mm 1.029-1.032 in
Crankshaft Thrust Wall Width (Service) 26.32 mm (Maximum) 1.036 in (Maximum)
Cylinder Bore
Cylinder Bore Diameter 99.0-99.018 mm 3.897-3.898 in
Cylinder Bore Taper Thrust Side 0.018 mm (Maximum) 0.0007 in (Maximum)
Cylinder Head
Cylinder Head Engine Block Deck Flatness (Measured within a 152.4 mm (6.0 in) area) 0.11 mm 0.004 in
Cylinder Head Engine Block Deck Flatness (Measuring the Overall Length of the Cylinder Head) 0.22 mm 0.008 in
Cylinder Head Exhaust Manifold Deck Flatness 0.22 mm 0.008 in
Cylinder Head Intake Manifold Deck Flatness 0.22 mm 0.008 in
Cylinder Head Height (Measured from the Cylinder Head Deck to the Valve Rocker Arm Cover Seal Surface) 120.2 mm (Minimum) 4.732 in (Minimum)
Engine Block
Camshaft Bearing Bore Diameters 55.063-55.088 mm 2.168-2.169 in
Engine Block Cylinder Head Deck Surface Flatness (Measured within a 152.4 mm (6.0 in) area) 0.11 mm 0.004 in
Engine Block Cylinder Head Deck Surface Flatness (Measuring the Overall Length of the Block Deck) 0.22 mm 0.008 in
Engine Block Cylinder Head Deck Height (Measuring from the Centerline of Crankshaft to the Deck Face) 234.57-234.82 mm 9.235-9.245 in
Main Bearing Bore Diameter (Production) 69.871-69.889 mm 2.750-2.751 in
Valve Lifter Bore Diameter (Production) 21.417-21.443 mm 0.843-0.844 in
Intake Manifold
Intake Manifold Cylinder Head Deck Flatness (Measured at Gasket Sealing Surfaces) 0.5 mm 0.02 in
Oil Pan and Front/Rear Cover Alignment
Oil Pan to Rear of Engine Block Alignment (at Transmission Bellhousing Mounting Surface) 0.0-0.25 mm (Maximum) 0.0-0.01 in (Maximum)
Front Cover Alignment (at Oil Pan Surface) 0.0-0.5 mm 0.0-0.02 in
Rear Cover Alignment (at Oil Pan Surface) 0.0-0.5 mm 0.0-0.02 in
Piston
Piston Outside Diameter (at Size Point) 98.964-98.982 mm 3.8962-3.8969 in
Piston to Bore Clearance (Production) 0.018-0.054 mm 0.0007-0.00212 in
Piston to Bore Clearance (Service Limit) 0.018-0.054 mm (Maximum) 0.0007-0.00212 in (Maximum)
Piston Pin
Piston Pin Clearance to Piston Bore (Production) 0.01-0.02 mm 0.0004-0.00078 in
Piston Pin Clearance to Piston Bore (Service Limit) 0.01-0.02 mm (Maximum) 0.0004-0.00078 in (Maximum)
Piston Pin Diameter 23.997-24.0 mm 0.9447-0.9448 in
Piston Pin Fit in Connecting Rod 0.02-0.043 mm (Interference) 0.00078-0.00169 in (Interference)
Piston Rings
Piston Compression Ring End Gap (Production Top) (Measured in Cylinder Bore) 0.23-0.38 mm 0.009-0.0149 in
Piston Compression Ring End Gap (Production--2nd) (Measured in Cylinder Bore) 0.44-0.64 mm 0.0173-0.0251 in
Piston Oil Ring End Gap (Production) (Measured in Cylinder Bore) 0.18-0.69 mm 0.007-0.0271 in
Piston Compression Ring End Gap (Service-Top) (Measured in Cylinder Bore) 0.23-0.38 mm (Maximum) 0.009-0.01496 in (Maximum)
Piston Compression Ring End Gap (Service--2nd)(Measured in Cylinder Bore) 0.44-0.64 mm (Maximum) 0.0173-0.0251 in (Maximum)
Piston Oil Ring End Gap (Service Limit) (Measured in Cylinder Bore) 0.18-0.69 mm (Maximum) 0.007-0.0271 in (Maximum)
Piston Compression Ring Groove Clearance (Production--Top) 0.04-0.085 mm 0.00157-0.003346 in
Piston Compression Ring Groove Clearance (Production--2nd) 0.04-0.08 mm 0.00157-0.003149 in
Piston Oil Ring Groove Clearance (Production) 0.01-0.22 mm 0.0004-0.00866 in
Piston Compression Ring Groove Clearance (Service--Top) 0.04-0.085 mm (Maximum) 0.00157-0.003346 in (Maximum)
Piston Compression Ring Groove Clearance (Service--2nd) 0.04-0.08 mm (Maximum) 0.00157-0.003149 in (Maximum)
Piston Oil Ring Groove Clearance (Service Limit) 0.01-0.22 mm (Maximum) 0.0004-0.00866 in (Maximum)
Valve System
Valve Lifter Hydraulic Roller
Valve Rocker Arm Ratio 1.70:1
Valve Lash Net Lash--No Adjustment
Valve Face Angle 45 degrees
Valve Seat Angle 46 degrees
Valve Seat Run-out 0.05 mm (Maximum) 0.002 in (Maximum)
Valve Seat Width (Intake) 1.02 mm 0.04 in
Valve Seat Width (Exhaust) 1.78 mm 0.07 in
Valve Stem Clearance (Production--Intake) 0.025-0.066 mm 0.001-0.0026 in
Valve Stem Clearance (Production--Exhaust) 0.025-0.066 mm 0.001-0.0026 in
Valve Stem Clearance (Service--Intake) 0.093 mm (Maximum) 0.0037 in (Maximum)
Valve Stem Clearance (Service--Exhaust) 0.093 mm (Maximum) 0.0037 in (Maximum)
Valve Stem Diameter (Production) 7.955-7.976 mm 0.313-0.314 in
Valve Stem Diameter (Service) 7.9 mm (Minimum) 0.311 in (Minimum)
Valve Spring Free Length 52.9 mm 2.08 in
Valve Spring Pressure (Closed) 340 N at 45.75 mm 76 lb at 1.80 in
Valve Spring Pressure (Open) 980 N at 33.55 mm 220 lb at 1.32 in
Valve Spring Installed Height (Intake) 45.75 mm 1.8 in
Valve Spring Installed Height (Exhaust) 45.75 mm 1.8 in
Valve Lift (Intake) 11.99 mm 0.472 in
Valve Lift (Exhaust) 12.15 mm 0.479 in
Valve Guide Installed Height (Measured from the Cylinder Head Spring Seat Surface to the Top of the Valve Guide) 17.32 mm 0.682 in
Valve Stem Oil Seal Installed Height (Measured from the Valve Spring Shim to Top Edge of Seal Body) 18.1-19.1 mm 0.712-0.752 in
Approximate Fluid Capacities
Cooling System
Automatic Transmission 11.6 Liters 12.3 quarts
Manual Transmission 11.9 Liters 12.6 quarts
Engine Crankcase
With Filter 6.1 Liters 6.5 quarts
Without Filter 5.7 Liters 6.0 quarts
Fuel Tanks (Total) 72.3 Liters 19.1 gallons
Rear Axle Differential
Lubricant 1.6 Liters 1.69 quarts
Limited-Slip Additive 118 Milliliters 4.0 ounces
Transmission Fluid
Drain & Fill (Automatic Transmission) 4.7 Liters 5.0 quarts
Overhaul (Automatic Transmission) 10.2 Liters 10.8 quarts
Overhaul (Manual Transmission) 3.9 Liters 4.1 quarts
Engine Type V8
Camshaft
Connecting Rod
Crankshaft
Cylinder Bore
Cylinder Head
Engine Block
Intake Manifold
Piston
Piston Pin
Piston Rings
Valve System
Cooling System
Engine Crankcase
Transmission Fluid
Re: Rod Bearing?
Thanx everybody. I figured it out I went ahead and tried it and saw they came out. Once I got the bolts loosened I saw the seam. Looks like My oil pump had been cutting in and out, cause the bottom of the bearing was the only thing scored. Since thats the last place the oil will run to on the bearing. Although my gauge never fluctuated, never did drop below 40p.s.i.
