Leakdown Results
Leakdown Results
So I had a compression and leakdown test on a new 440 LS7.
They're all 12-14% except one with 19%.
The rings are plasma moly Hellfire rings for nitrous possibly later.
Results are after 500 miles.
Does this sound ok to you?
Engine hot or cold? Forged pistons i assume? ring gaps? these would be helpful, doesn't sound bad though still probably has a little breaking in to do
Leakdown Results
No. I recently did a leak-down test on my 427 and all cylinders (except one) were under 5% leakage on a cold engine. This engine has over 100 passes on it. To me, anything over 10% is not good.
