Oil smoke on Decelleration???
Old 12-09-2008, 04:39 PM
LS1Pariah's Avatar
Default Oil smoke on Decelleration???
I've got an 02 LS1 in my Miata, and I have noticed that after hard accel, during decel, it intermittantly lets out some oil smoke. I took it to a local LS1 performance shop and they suggested to get the LS6 valley cover, and PCV, and also run a catch can. Well they went ahead and did that at the cost of $700 and during a 2nd through top of 4th pull sunday it did it again. I called the shop and the head guy is at a PRI show this week, but the guy on the phone said something about the oil rings fluttering or something like that?? Any input is appreciated.
Old 12-09-2008, 04:50 PM
1BADAIR's Avatar
pull the pcv hose off at the intake and check for oil
Old 12-09-2008, 05:35 PM
99SSragtop's Avatar
Valve seals
Old 12-09-2008, 05:39 PM
LS1Pariah's Avatar
Valve seals would leak during the night causing smoke on initial start-up wouldn't they?
Old 12-09-2008, 09:24 PM
SSTYCOON's Avatar
my 98 ls1 smoked just like yours when I had it. Gett use to it.... you've got an oil burner. It seemed like it started doing it after I got my Mac headers.
Old 12-09-2008, 11:32 PM
the_merv's Avatar
Mine used to do it on Decel too, then I found out that it was coming out one of the Breathers, so I hooked the PCV System back up.
Old 12-09-2008, 11:35 PM
99SSragtop's Avatar
Not 100% sure on that, when there cold they could seal better ????
Old 12-10-2008, 01:18 AM
the_merv's Avatar
When they get warm and expand, then I can see them sealing better..
Old 12-10-2008, 12:24 PM
LS1Pariah's Avatar
Hey Merv, yea that's what we did to correct it, but it's still doing it... Bummer.
Old 12-10-2008, 03:22 PM
SladeX's Avatar
Earlier LS1 cars, particularly in vettes had an issue at higher rpm would get ring flutter at which would eat up oil in large amounts, like as much as 1 quart in 1k miles. This would happen in 2nd gear in the mid rpm range mostly. Gm's solution to this was to alter the driver's habits by ie shifting to the next gear.
If it still happened to consume oil, then they would change the rings. If on decel, you are going through the exact same conditions as those early cars, then you'd get oil going by the rings.
Old 12-10-2008, 05:09 PM
Formulized94's Avatar
A buddy of mine has a 2000 z28, it does the same thing. He did put a catch can on it and it helped a little but the engine still does it every now and then, after hard acceleration.
Old 12-10-2008, 06:10 PM
Rychen's Avatar
sounds like rings to me.
Old 12-10-2008, 07:14 PM
ksk1980's Avatar
yep id say rings also
Old 12-10-2008, 09:05 PM
SOMbitch's Avatar
Old 12-10-2008, 10:29 PM
SSTYCOON's Avatar
the guy is right about ring flutter or atleast thats what GM called it. My 98 Z was built in late 97, so I had an earlier motor. I went racing 1 day, prolly made 15-20 passes and used 3 qts of oil. she ran good though!!
Quick Reply: Oil smoke on Decelleration???
