Quick Head install ?
Old 12-14-2008, 10:20 PM
samh_08's Avatar
Default Quick Head install ?
Long story short, I installed one of my heads and ending up only torquing all of the bolts to 22 ft./lbs and not finishing the rest of the procedure. I should be able to continue where I left off at another time, correct?
Old 12-14-2008, 10:26 PM
Skeet Skeet's Avatar
Yeah as long as you dont start it or anything. I dont see why you wouldnt be able to
Old 12-14-2008, 10:54 PM
samh_08's Avatar
Anyone else want to back this up?
Old 12-14-2008, 11:14 PM
1FastBrick's Avatar
As stated previous You will be fine as long as you don't start it... I also would not fill it with any fluids till It tourqued properly.
Old 12-15-2008, 09:41 AM
Uncle John's Avatar
As per the procedure, the top five bolts should be torqued last. If you loosen them and are using "torque to yield" bolts, they will have to be replaced.
