Passenger turn signal not blinking
tried replacing the bulb? alot of time 1 filament will burn out causing it not to blink... the arrow will just stay on when you turn the blinker on to let you know you have a bulb out.
Same thing used to happen to me on a monthly basis. Always changed the bulb, and that always fixed it. It's been a while since it's happened, so I probably just jinxed myself, and now they will BOTH go out, and catch on fire.
Totally replace the buld...$5 fix. I notice this alot when cars in front of me seem not to signal, then when you pass them their front turn signal is going ape ****. Good thing you have LS1tech.com as THEY (everyone else) will probably loose $50+ to a mechanic to swap a bulb...this is the deetaadee factor!
The bulb may be an issue, but might not solve the problem. Look at the way the bulb is sealed into the housing, that could cause more of a problem than just the bulb burning out.
